[B]Help with info on "Do it yourself" Brakes
Where can I find info on doing a complete brake job on 2005 A8? What are the best replacement performance (low cost) parts? Thanks for your help...
Well you can't do the rear brakes without the VAG COM tool www.ross-tech.com because you have to collapse the electronic rear caliper pistons, other than that the fronts are pretty straight forward. I would look on audiworld for a step by step instruction.
Parts can be found at www.ecstuning.com, www.purems.com www.germanpartsonline.com
