D3 A8 passenger CV keeps popping off of shaft after changing boots
HI All,
I recently had to replace the inner and out CV boots for the passenger side axle. I bought the proper kits (GKN) and installed the boots and regreased everything. The first time it happened I had only driven about 50 miles and I figured maybe I didn't seat the CV properly. The second time it happened I went about 100 miles before the CV popped off again, stranding me 50 miles from home. I made sure to replace the circlip and watched as I seated it before reinstalling. Any thoughts about what I may have missed or done wrong? I've done so many of these on Golf, Passats and my A4 without issue. What I did notice is that there is only a circlip on the A8 shaft while on the past ones I've done there was a spring washer and a plastic piece that were installed along with the circlip. Any help is appreciated. Thanks, Ron |
i did all four of mine about four months ago. there is a dished washer, a plastic 'spacer" and lastly a circlip; on the outer end(wheel end).
You may have the sides swapped. One side is longer than the other. Also possible you didnt clock the CV joint correctly, the center section with the balls inside of the CV stub . it will go together wrong from what i remember. |
Originally Posted by glenbjackson
(Post 1541379)
