Detailed motor now engine light on ?
Yes ! Im stupid. I detailed the motor using simple green and a hose. I spayed water over entire motor compartment. Now my A8 engine light is on and the car has no power and idling ruff like it wants to stall. Any help ?
You got water on the coil packs, take them out, dry them off, then try it.
Thanks AudiTech
Please everyone learn from me ! Do not spray water on ignition coils ! There are eight total ( on my A8 ) I shorted out 4 of the eight and ended up replacing all 8 (dealer rec). $44.0 each plus labor. almost $600 !!! That was one expensive car wash !
Sorry to hear about that mate, at least you know now. When i detail the engine compartment of an audi stay away from the coils with a pressure washer and i pull them out and dry them shortly after. That goes for all cars with COP (coil on plug) coil packs as well.
Originally Posted by 2005AudiA8
(Post 1001881)
Thanks for the info.:cool: |
Wash gone bad...
Thought I would drop an update on the post motor wash. I had 4 bad coils but they suggested that I replace all eight. The day after I got my car back the engine light came on so back to Audi I went. They tested it and said it was a catilitic converter falt. They reset it and I was on my way...
Next morning engine light was on again, back to audi. They told me that I needed to replace the catilitic converter(s)? "dont worry the emissions system has a 8 year warrenty" Ready on Friday ! NOT ! I got a call that they will have to pull the engine and tranny to fix the converter ! Maybe Tuesday or Wednesday now. I may never open my hood again ! |
(Post 1008386)
If you let your engine misfire enough from bad coil packs it can damage the cat converters in a hurry. What happens is when the engine misfires, excess fuel doesn't get burned in the combustion chamber and gets sent through the exhaust and into the cats, the fuel then ignites inside the cat converters and breaks them down, giving you that rotten egg smell if its really bad. You will also notice that they will now glow if they are really bad.
Oh, and it doesn't require pulling the engine to change out the cats, they just say that to get paid more hours of labor through audi warranty. Audi will eventually catch on to that fact and bust the techs balls. So there isn't any risk of them pulling the motor, it will actually only take about 4 hours to change the cats. The cat converters are under a federall warranty which states any vehicle with less than 80k or a certain amount of years (i think 5) is subject to repair free of charge. Its an "attempt" to clean up the enviroment. ;)
Originally Posted by auditech79
(Post 1008581)
Once there's a SES light and the car feels wrong, fix it or get it flatbedded - right away!:o Good info. |
