drain spots on A8 97'
Old Jan 3, 2010 | 05:52 AM
dannyghost's Avatar
Member
Default drain spots on A8 97'
ok,
I spoted an amount of water in compartemnt under the wipers.Where are the drain spots ? could they be closed with leafes or similar crap?
pictures would help.thanks
Old Jan 5, 2010 | 12:27 PM
dannyghost's Avatar
Member
nobody knows where are the drain holes in front?
Old Jan 5, 2010 | 01:52 PM
AWDaholic's Avatar
Senior Administrator
do a search for a8 drain plug. or, scroll down through the threads. I know it's been posted up about a hundred times, every owner of a D2 on here has asked, at least once. and, yes, they get clogged up with leaves, and stuff, and you end up with wet-shoes, eventually.
Old Jan 5, 2010 | 04:07 PM
dannyghost's Avatar
Member
Old Jan 5, 2010 | 08:00 PM
AWDaholic's Avatar
Well, at least it's a simple procedure, AND easy to reach, huh?
Old Jan 6, 2010 | 01:42 AM
Brozee's Avatar
Dear god that looks hard! Good luck with all of that I know I sure as heck wouldn't ever even attempt it.
Old Jan 6, 2010 | 10:17 AM
auditech79's Avatar
Its not as hard as it looks, the A8 comes apart pretty easilly, its much better designed than the A6 or A4.
Old Jan 6, 2010 | 11:10 AM
Brozee's Avatar
Thank god I have an a8
Old Jan 6, 2010 | 11:30 AM
dannyghost's Avatar
Member
easy totake apart, but who is gonna get it back in one piece?
ok, I understand regarding small drain spots , but how can i get that central drain before i remove trannsmision down?
I am not going to start on that a/c drain system, with orange pipes....after that, my A8 will be turned into drag car..
Old Jan 6, 2010 | 02:52 PM
auditech79's Avatar
Well i doubt its the A/C evaporator drain lines, for them to leak you would have to have the A/C on, unless you're running the defroster. Try leaving the defrost off and see if it still leaks, if there is still a leak then its probably the drain in the engine bay.
