Oil leaks, brake squeaks '98 4.2
Old Dec 18, 2009 | 04:09 PM
gerryinOlyWa's Avatar
Question Oil leaks, brake squeaks '98 4.2
I'm losing quite a bit of oil, maybe 1.5 qts per month to leaks. I'm pretty certain the car isn't burning the oil, 'cause of the puddles of oil on the ground. Car runs fine, but I'm getting tired of the mess. Is this a must do protective maintenance repair, and if so how much will it cost?
Also, my breaks squeak loudly. I took them into the shop and they lubricated something on the front end and that seemed to work. Now they're squeaking in back. What's up?
Love this car!
Old Dec 19, 2009 | 08:33 AM
dannyghost's Avatar
Member
well, regarding oil leaks, it would help if you know under which area si leak.
it could be faulty or warn gasket, I had problem with loosing oil on my both camshaft endings, gasket was worn down..it takes to pull tranny out, and a lot of messy business.
also, your oil pan can be leaking
trannsmission could
..so basically, wash your engine, let it dry and put big piece of paper to see where is loosing oil (before washing, protect electronics)
for squeeking noise..its due to breaking pads..some mixes are too hard, maybe u can invest and buy "racing pads" which are more softer but they last much less.
Edo
Mar 20, 2015 07:53 AM
A5Pete
Mar 21, 2013 02:06 PM
wildlife9000
Nov 9, 2007 09:58 PM
a6lovely
Dec 12, 2006 05:32 PM
andrewfournier
Mar 9, 2004 04:25 PM
