oil or mud?
RE: oil or mud?
ORIGINAL: Jeff
y cut corners. really how much money are you going to save. if you own an audi freakin change the oil and the filter. i change my oil ever 3k miles. and i run fully synthetic
RE: oil or mud?
look, im trying to figure out why audi would putthis in the manual about the oil. then im reading in there that mixing any anti freeze is like, stop, pull over, the motors about to blow! then i ask around and anyone with mild knowledge looks at me like, what are you stupid? 10,000 oil? never change your tranny fluid? no dip stick? i say why not make sense audi? or adleast tell your dealers something logical as an explaination.
#18
RE: oil or mud?
Well, I've got an O/C coming up, and I'm thinking about trying out Royal Purple. As far as "other" experiments... One of these weekends I'm switching to a higher boiling-point brake fluid and S/S lines, to go with my already drilled/slotted rotors.
Reports to the A8 section as info comes in/impressions are generated.
baby steps...
Next steps after that will be a cold-air-intake and a tip-chip, respectively...
baby steps
baby steps...
baby steps
#19
RE: oil or mud?
Audi's are ok to run up to 10k miles if you are using a full synthetic.. a few friends have sent oil samples in and had them tested at 5k and 10k miles, and they were the same.
Changing the filter and not the oil makes no sense what so ever..
If you change the filter change the oil.
