ruff idle flashing check eng light
STOP DRIVING IT IMMEDIATELY!!!!!! A flashing check engine light only means one thing......MISS FIRE. Which means if you keep driving it your probably gonna need a new engine pretty soon.
9 times out of 10 you have a bad ignition coil, they suck and always fail.[:'(]
it is DEFINITELY a misfire...probably mulitple. If you are in the USA, run to pepboys or autozone or advanced auto and pick up a OBDII reader or if you are planning on keeping the A8 a lil while, go to ross-tech.com and order the VAG-COM software to check your codes. I would definitely not drive it more than you have to. Things to check are spark plugs, coilpacks, power output stages, ECU, compression, and worst - Timing Belt.
AWD_Addict
May 18, 2011 04:42 PM
