Is it safe to leave DRL with aftermarket Xenon's ?
Hi,
I have a '97 A8 with stock halogen headlights. I will be installing a HID kit for the low-beams, but i'm concerned with the DRL's that send less power to the headlights when on (DRL = 80% power... dimmer halogen light, Lights ON = 100% power.. normal light).
Could this affect the HID ballasts?
Should I be better off disabling completely the DRL's ?
thanks
thanks
You should be fine, if your going to say that, just about every car comes across that problem and gets with it fine. If the car needed more power I think it could manage and get that power to the headlight. It should work fine for you.
