Transmission/differential oil leak
Hello !!
I´m quite green with my A8 and now there is some smell of oil under it. I took a look under car and both catalysators are covered with oil, super !! Does anyone has a picture or part list, if I change ALL possible seals to differential and gearbox at one time? Part numbers or sizes on seals are good enoughtoo. My car is A8 Quattro, ABZ-engine and with 4-speed automatic transmission. Why I want to change all seals? Well, two month ago, I change my timing belt. Everything goes well, till one weeks has gone. Oli pump seal start leaking oil. So I change it. One week later, crankchaft seal start leaking oil. So my blood pressure raise up and I change all sealsfront of engine. In fackt, I installed TWO seals to every place, insted of normal one seal (believe, there is a lotof space to install two). And I expected to see never oil out of engine again. And what happened... three weeks after, oil again. This time oil is from gearbox or differential. So, if You have links, pictures, part numbers or sizes of the seals, I´m moore than happy to get information. And if You need sizes of engine front seals, I can give them to You. Thanks for Your time. /pete |
