Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
ESP and ABS lights are both on - advice needed
Old Dec 20, 2013 | 09:17 AM
bab2013's Avatar
Default ESP and ABS lights are both on - advice needed
Hello everyone
I have a 2007 Audi Q7 3.0 with 75K miles (US spec car). My ABS and ESP lights are on and VAG-COM is pretty clear on what's going on:
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
014 -- Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 120102 km
Time Indication: 0
Date: 2013.12.16
Time: 14:03:02
Freeze Frame:
Count: 1792
Count: 8195
Count: 104
Count: 51456
However, if I reset the code above and the lights go off, for the 30 seconds or so before they come on, the ESP button works to turn traction on and off and the ABS kicks in if breaking on slippery ground. As I said, a few seconds after starting the car and rolling it (whether breaking or not) both lights come back on. Am I SOL and have to get a new pump or could this be caused by a faulty capacitor, pressure sensor etc?
Also, I have searched around the forums and there seems to be an ABS fuse, apparently located on top of the battery under the driver's seat. I unscrewed and reclined the seat, found the battery underneath but there is no fuse bank on top of it. Am I missing something? None of the other fuse banks I found have an ABS one either.
Any help would be greatly appreciated.
Thanks guys!
Old Dec 22, 2013 | 09:13 PM
bab2013's Avatar
Anyone? It seems like a lot of people looked at this but there are no suggestions. I assume a new pump it is...
Old Dec 30, 2013 | 08:02 AM
cartronicshn's Avatar
good luck on here, i asked the same question a couple months ago, and never received any help, as many others , it seems that the people that used to help around here are long gone, to bad for us.....
Old Dec 30, 2013 | 08:08 AM
bab2013's Avatar
That's unfortunate... I posted this on another forum as well, still no feedback. Have you been able to fix yours? The baffling thing is that I can't find the ABS fuse.
Old Dec 31, 2013 | 11:28 AM
went to the dealer, they hooked up the computer, and they want to change both mafs , epc and a whole bunch of other electronics which come out to almost $6k, i've had the esp light go out after one hard launch on a gravel road, and it sayed that way for a month or so, the car was running normally, then i hit a bad patch of road with some bad potholes and the light came on again, this would indicate sensor or computer connectors, i'll let you know what i can find at the dealer.
Old Dec 31, 2013 | 12:10 PM
M5S5's Avatar
Tech Certified
You will need a new pump.
Old Dec 31, 2013 | 12:19 PM
M5S5's Avatar
Tech Certified
The reason is there are too many spamming individuals that pollute the forums with nonsense advertising will/awe , blau parts , ect , ect along with other spammers.
Old Dec 31, 2013 | 12:43 PM
bab2013's Avatar
Any idea where the fuse should be?
Old Sep 26, 2014 | 11:12 AM
bab2013's Avatar
Resurrecting this thread. I do need a new pump (dealer confirmed). Any idea where this is located?
tmeyer
Jan 19, 2013 03:08 PM
Goodies6
Apr 27, 2010 09:51 PM
nycqtplayazz
B7 Models
Mar 25, 2009 04:22 PM
AudiA4Girly
Sep 13, 2007 10:29 PM
mav
Aug 24, 2005 07:53 PM
