Q7 Brake Controller Install
Hi guys!
I have been searching the Internet for days, I've called 5 dealerships, two trailer supply houses, yet I still can't get an answer... Can somebody please tell me where to get or what the part number is for the harness that plugs in under the dash of a 2011 Q7 TDI with a factory tow package to hook up a trailer brake controller? I've seen a few people say "I simply plugged in the harness under the dash and wired it to my brake controller" but I can't find where to get the dang harness! Thanks in advance! :) |
Re: Brake controller install
Hi, Wondering if you ever got your brake controller problem solved? I have a Q7 '09 and am just running into similar problems. No one wants to install it for me and Audi centers tell me they won't touch aftermarket stuff, so not sure how I bought a vehicle rated for towing with a tow set up and now they won't help me out with and install so I can tow.
I'm hoping you've worked through this problem and have now found success? |
Originally Posted by wjules
(Post 1434102)
I'm hoping you've worked through this problem and have now found success? I'm also wondering where others are mounting the controller. |
Q5 Brake Controller
Hello,
I am having trouble determining if the computerized system in my newly purchased 2011 Q5 performs the functions of a trailer brake controller or not. Does anyone here have experience with this and know if I need a separate brake controller and if so does that mean an after market one or does Audi make a unit for this function? I have a really hard time accepting that a company like Audi has not thought this through but I keep coming back to needing some darn after-market gizmo installed around the drivers feet which just seems wrong to do to such a well thought out car. Any help or insight would be really appreciated. Mark Nay - Pasadena, CA |
Originally Posted by MarkNay
(Post 1468278)
Hello,
I am having trouble determining if the computerized system in my newly purchased 2011 Q5 performs the functions of a trailer brake controller or not. Does anyone here have experience with this and know if I need a separate brake controller and if so does that mean an after market one or does Audi make a unit for this function? I have a really hard time accepting that a company like Audi has not thought this through but I keep coming back to needing some darn after-market gizmo installed around the drivers feet which just seems wrong to do to such a well thought out car. Any help or insight would be really appreciated. Mark Nay - Pasadena, CA I installed all thats needed in to my 2010 Q5 a while back. Are you asking if the 6 pin connector as part of the tow package comes with the ability to controlll your trailer breaks? the answer is kinda. You still need a break controller that isn't supplied by audi. There is a 4 pin connector under your steering wheel where you can create a connector and connect that to an after market break controller. Does this help or do you have more questions? |
I'm about to wire my controller in to the car. According to the paperwork I have, it would appear that the wiring would go as follows:
Car end connector to Tekonsha controler 1 brown to White 2 red/yellow to black 3 black/red to red 4 blue to blue The numbers are what's listed on the female connector I bought from Audi that plugs in to the male connector under the dash of my Q7. I'll add pics of my setup which if works out will allow me to remove the controller with ease when not in use and if all works out, will hide the mounting location. Ah only if ideas were easier to make a reality ;). Wish me luck! |
Originally Posted by Ponch
(Post 1468708)
(Post 1469410)
So just to confirm, although the colors on my car aren't as labeled here, I was able to make the cable and test with my break controller. Next step is mounting so that it's either hidden or removable without signs of having one... lots of ideas with little skills ;). My next project is the removable mount for the Brake Controller itself. I found the connector I need, now just need to mount. Wish me luck. |
5 Attachment(s)
(Post 1471074)
One step closer. I've wired a connector (plug you'd find on a computer power supply that connects to an old hard drive) so now I can easily disconnect my brake controller when not in use.
My next project is the removable mount for the Brake Controller itself. I found the connector I need, now just need to mount. Wish me luck. the reason I wanted this is I didn't want to damage the car and I don't keep the controller on all the time, only when needed. Sorry about the poor quality pics ... if anyone is interested in the way I did this, I can take better or more detailed ones. Cost of connections, $0.60 I painted it flat black for looks. $12 in paint and I had liquid plastic to secure the second part to my break controller. $0.00 Oh and I also wired a computer power supply male/female connector (taken out of a dead computer) for easy connection ... seen in the last pic. $0.00 the wire running across from left to right if my dash cam power cord. Still need to wire that thing in also. |
Hello Ponch. Do you have a part number for the female connector. How did they know to give you the one that fit the male?
