"Brake" Problems
Old Mar 5, 2007 | 04:14 PM
cincyTT's Avatar
I'm make believe
Default RE: "Brake" Problems
you never posted if your brake fluid was dropping or was below the min level. If it is then you might have a leak because i doubt you are driving so aggressively that its boiling. Also, does you car have wear sensors? some cars have it on the pads and that light would be a good indication that you need new pads and then it will go away. And when you install your new brakes, i would flush the system and refill with what xclr8tt listed above.
Old Mar 5, 2007 | 04:16 PM
XCLR8TT's Avatar
DOT4 is fine for the street. But since you are going to change it, go ahead and get the DOT5 spec, which gives you a slightly higher boiling point.
Old Mar 5, 2007 | 04:19 PM
cincyTT's Avatar
I'm make believe
i wanna know who is boiling over dot4 on the street in a mild TT? i can see a 400whp car but not one not even pushing 300whp, unless you are going 60-0 every 30sec.
Old Mar 5, 2007 | 04:23 PM
ouTTie914's Avatar
Ahh, I like your thinking Steve!
Just because I think it's useful:
Boiling Point Ranges
Dry Boiling Point / Wet Boiling Point
DOT 3: 205°C (401°F) / 140°C (284°F)
DOT 4: 230°C (446°F) / 155°C (311°F)
DOT 5: 260°C (500°F) / 180°C (356°F)
DOT 5.1: 270°C (518°F) / 191°C (375°F)
Old Mar 5, 2007 | 05:00 PM
moeron7's Avatar
Ok well i'll change out my pads and rotors( i think they're shot) and see if this fixes it . I 'm not sure if i have sensors as i have not checked to see. But i've looked everywhere around here and couldnt even find DOT4 brake fluid. I woul like to upgrade but right now i dont have the cash. I'll have a new CC in a couple of days to afford an upgrade on my rotors and pads but do you think i could wait that long? Would a VAG-Com tell me exactly whats up with my ride?
Old Mar 5, 2007 | 05:03 PM
225tt's Avatar
Steve you mainly use your TT for the track right, so this is why you would want a higher boiling point for your TT just to be on the safe side during races, no sense having to worry about your brakes in a race, just drive right??
Old Mar 5, 2007 | 05:08 PM
ouTTie914's Avatar
Vag-Com would only tell you if you're throwing a code. Did you replace the hazard relay switch yet moeron?
I'm sure you can get brake fluid from the dealership.
Old Mar 5, 2007 | 05:11 PM
  #18
moeron7's Avatar
No the hazard switch is still messed up, i went to go get it switched and they wanted around $80. I thought that was terrible for a 10 minute job. Do you know where I can get one? I can do the install myself for sure, i have friends that work at audio places to use the head unit keys so thats no prob. Do you think these problems are related?
Old Mar 5, 2007 | 05:24 PM
  #19
ouTTie914's Avatar
Look what I found when I did a search!
Old Mar 5, 2007 | 05:43 PM
  #20
moeron7's Avatar
Thanks, I've read that before I just didnt have the $ at the time. Just ordered one. Do you think that would be related to my other problems though?
