01 TT Quattro- Overheating Hell
Old Nov 19, 2007 | 04:05 PM
Stpinmass's Avatar
Default 01 TT Quattro- Overheating Hell
[align=left]Just looking for some help.. I have an 01 Audi TT Quattro.. The temp guage started fluctuating about 2 months ago.. Irradically.. Going from middle bar to 2nd bar to the right, then back down again.. Called Audi, said it was possibly the instrument cluster. Common problem with TT's.. Brought it in.. They said it was the water pump.. Said top hose was hot going to radiator, and bottom hose was cold.. (last I checked that's a problem) Temp should be 15 to 20 degrees lower than top hose.. Brought it to inde mechanic, replaced timing belt/water pump.. (mind you at half the price Audi quoted me).. Car is still overheating.. (heat works fine) going to be replacing thermostat, and checking for blockages.. Any additional ideas would also be appreciated..
[/align]
Old Nov 19, 2007 | 04:21 PM
.clipse's Avatar
SoCal Crew Member
Default RE: 01 TT Quattro- Overheating Hell
^ how many miles does your TT have?
over 60k, you should do your timing belt along with your waterpump since they both go out simultaneously around the same time.
Old Nov 19, 2007 | 04:40 PM
Murderface's Avatar
It could be your cluster, and it could also be your coolant temp sensor. Audi used to fit a sensor in there that was known to give weird readings...later they replaced it with a "green top" sensor. It's a $25 part. www.ecstuning.com
Old Nov 19, 2007 | 05:46 PM
diehlryan's Avatar
could be air in the cooling system.
Old Nov 25, 2007 | 12:32 AM
Product084's Avatar
what about the tensioner? did you replace that.Also is the car leaking coolant cause if so you may have a bad hose or you need a new thermostat
Old Nov 25, 2007 | 12:34 AM
Product084's Avatar
also remember to buy an O-ring with your new thermostat
imaudi5000
B7 Models
Jul 4, 2014 11:27 PM
Pbcrazy
Jul 14, 2012 10:40 AM
S3_Quattro
Aug 13, 2008 12:17 PM
msa10
Mar 2, 2006 08:02 PM
MeadowsMD
Oct 8, 2004 10:29 AM
