12.50 1/4 2871 eliminator
http://www.eurodyne.ca/index.php?s=galleryVideo on bottom of page.... 2871r atp eliminator kit, 660cc injectors, 3" inlet pipe, eurodyne big turbo software. Stock intake, stock intercoolers, stock exhaust! Not bad there may be hope for the Elim kit after all
Idont know?....Chris from unitronic emailed me back about it said it was a 2871r eliminator kit w 660cc and their tune....the 12.9 vid is the first install at the end of the video it tells whats doen to the motor...so unless he lied in his email back to me...who knows
Even on a stock turbo?? Really? whats the max psi you can run the little k04 up to before it tears itself apart?.... Im thinkin about going a completly diff rout the more and more i look around at turbo kits....and start from scratch from block up and just by an OEM with stroker 2.0 kit and building piece by piece. So many choices lol
Yes on the stock turbo. With all the bolt ons: turboback, intake, fmic, chip with race file. Mix in water/meth, ebc, 25-26psi, and some light weight wheels w/ sticky tires and you should be there easy. If not, go on a diet. For low 12's you could get an intake manifold and add a 75shot.
