16g turbo???
Old Nov 25, 2007 | 03:50 AM
jojoenglish85's Avatar
Default 16g turbo???
I have a 2001 audi tt 225 awd. Im wanting to upgrade the turbo with a 16g or big 16g from an evo. will i need any extra or additional parts to complete the swap of the two turbos? If so can you list what i will need for the project.
ps. i wanted to go with the big 16g because its a little step up from stock but im not trying to make serious power. I want the most i can get on my stock engine with my chip, and minor bolt ons.
Old Nov 25, 2007 | 04:01 AM
PCBOI808@HOTMAIL.COM's Avatar
Default RE: 16g turbo???
we could do good w/a chip,intercooler,w/m inj, and etc. a bigger turbo even a t3/t4 produces a lot of power
Old Nov 25, 2007 | 04:05 AM
if i chose the 16g or the t3/t4 will it fit directly or would i need other parts for it to fit correctly?
Old Nov 25, 2007 | 04:06 AM
no u would have to change the exhaust manifoldsetup and intercooler etc
Old Nov 25, 2007 | 04:09 AM
depending on power range
Old Nov 25, 2007 | 04:14 AM
that sucks, is there any other turbos out there that doesn't require new mani, etc....?
Old Nov 25, 2007 | 05:29 AM
Murderface's Avatar
ORIGINAL: jojoenglish85
Quite frankly nobody uses Mitsubishi turbos on 1.8T's. GReddy makes a kit, but it's only for FWD MkIV VW's (or FWD TT's) it uses a TD03-19H if I remember. And impressions of the kit weren't very good last I heard.
Anyway, since you have a 225 you already have the bigger K04 meaning you have no place to go other than bolt ons or a big turbo setup. So unless you wanna stick with bolt on gains, you'll need a new mani etc.
Old Nov 25, 2007 | 03:34 PM
ok, i had found this out today. take a look and let me know if its a waste of money. you said i already had this ko4 right?
so would it be worth it?
http://www.kineticmotorsport.com/pro...KIT-235-0.html
Old Nov 25, 2007 | 03:58 PM
cincyTT's Avatar
I'm make believe
That is smaller than the ko4-20/22/23 turbos used in the 225. As for the mitsu 16g, there isnt a manifold or dp made to use that setup. Its easier and more powerful to go with a standerd t3, t3t4, or gt turbo setup from garrett. You can get a excatly the power level you want and save yourself tons of work.
BTW, TT stands for Tourist Trophy...... NOT TWIN TURBO!!! You only have ONE turbo
Old Nov 25, 2007 | 04:00 PM
theTTkid's Avatar
does tt really stand for tourist trophy?
