180 and 225 engine Block, the same?
Old Jul 7, 2008 | 10:51 PM
bartvaio's Avatar
Default 180 and 225 engine Block, the same?
hello, look, my 225 audi TT engine block has a tiny crack made by the oil pump chain, does anyonw know if i can replace it with a 180 hp engine block? i know there are some diferences between them, but, is the engine block one of them?
thanks in advance....
Old Jul 7, 2008 | 11:23 PM
myslow1's Avatar
Default RE: 180 and 225 engine Block, the same?
as far as I know... i'm sure other people would know better
the blocks are going to be the same, the overall insides are different
the 180 has higher comrpression
dif sized wrist pins
the bore and stroke is the same though
Old Jul 8, 2008 | 10:57 PM
cincyTT's Avatar
I'm make believe
You can swap the block with any 1.8t from a Transverse Audi or VW. The 225 has some minor differences (speaking cast block, not internals) but nothing that makes it any better than the rest of them. Everything will transfer over. All other info is in the FAQ
Old Jul 8, 2008 | 11:44 PM
bartvaio's Avatar
problem solve in another thread:
https://www.audiforums.com/m_922307/tm.htm
thank you very much anyway.
Old Jun 13, 2020 | 04:36 PM
Matt Mankinen's Avatar
Default 225 long block swap into a 180
I have a 2001 180 quattro that the engine is shot. Someone is selling an engine from 225 model. Can I use the 225 block and head and swap everything over from the 180, intake exhaust, etc...?
josh A8
May 18, 2013 11:19 PM
antolin
Jan 27, 2012 08:31 PM
speedmetal1
May 2, 2008 01:22 AM
shawncumberland
Jun 19, 2007 06:56 PM
praetorian2150
Feb 4, 2006 05:19 AM
