180 vs 225 MAF
Old Apr 4, 2008 | 01:47 AM
Audi858's Avatar
Default 180 vs 225 MAF
What are the differance in these? Can the 225 MAF be used with the 180 housing and connector? Is the 225 MAF housing bigger than the 180?
Old Apr 4, 2008 | 03:36 AM
Murderface's Avatar
Default RE: 180 vs 225 MAF
ORIGINAL: Audi858
225 MAF=3" housing
180 MAF=2.5" housing
I don't think the elements are interchangeable since they're configured for the housings.
Old Apr 4, 2008 | 11:26 AM
Audi858's Avatar
gotcha but they can use the same connectors though right?
Old Apr 4, 2008 | 12:33 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: Murderface
ORIGINAL: Audi858
225 MAF=3" housing
180= 2.75" od housing.
The 225/vr6 housing wont fit in the stock airbox and shouldnt be used unless you are using a BT calling for it.
Old Apr 4, 2008 | 03:23 PM
Audi858's Avatar
yep im usign a BT software that was setup with a 225 MAF would i be able to get away with using my stock? What the differance in these just the housing size?
Old Apr 4, 2008 | 03:32 PM
cincyTT's Avatar
I'm make believe
The larger the housing the less airflow speed it reads. Your g/s will be to high and have fueling problems. You can get a 225/Vr6 maf for like $30. If you dont have one before you install the turbo, just run w/o the maf until you the correct size.
Old Apr 4, 2008 | 03:39 PM
Audi858's Avatar
ok so couldnt I fab up a MAF housing and use my existing MAF or are the sensors differant.
Where did you find the MAF for 30.00
Old Apr 4, 2008 | 03:48 PM
cincyTT's Avatar
I'm make believe
You can get them in forum classifieds for cheap when they are for sale. You can fab up a maf housing if you like. You just need to get the flange for it and weld it on the piping. Think 42dd or 20sqaured have one.
Old Apr 4, 2008 | 03:49 PM
Audi858's Avatar
ok so other wise the sensor's them self are the same thing, its just the housing that changes?
Old Apr 4, 2008 | 03:51 PM
cincyTT's Avatar
I'm make believe
Well, if you are going from a 180 to 225/vr6 maf, most tunes use the stock maf element.
