189 fwd help!
Old Feb 6, 2007 | 09:34 PM
craigtt's Avatar
Default 189 fwd help!
i have been replaceing parts fo 3 weeks now and i still cant stop my missfires, i replaced the coilpacks, plus, mas, fuel filter cleaned the injectors 3 or 4 times. at first i had a check light but it went away after i replaced the mas, im at my witts end and nobody could help me at ttcca so i swiched to you guys please help 2001 180 fwd conv
Old Feb 6, 2007 | 09:39 PM
cincyTT's Avatar
I'm make believe
Default RE: 189 fwd help!
what are your mods? what spark plugs are you using and thier gap?
Old Feb 6, 2007 | 09:48 PM
XCLR8TT's Avatar
Do you have VAG-COM or an OBD2 scanner to pull off any misfire codes? It would be helpful to see what if any codes you are getting.
If the misfires continue after replacing plugs and coilpack, it is most likely to be your harness. Take a look at this link for the DIY instructions... COILPACK HARNESS REPLACEMENT
Old Feb 6, 2007 | 09:59 PM
cincyTT's Avatar
I'm make believe
the harness has been know to crack and need replaced. that is a somewhat common problem.
Old Feb 6, 2007 | 10:00 PM
craigtt's Avatar
i have no mods , i used autolight double platnium(gaped to .032and i used an obd and i got a random misfire code and then a missfire code in every cylender
Old Feb 6, 2007 | 10:59 PM
XCLR8TT's Avatar
Sounds suspiciously like the harness.
Old Feb 6, 2007 | 11:49 PM
cincyTT's Avatar
I'm make believe
^ thats the one thing i can think that would cause miss fires in all cylinders even after coilpacks and plugs have been changed.
