2000 Audi TT Possible Piston Rings Problems
Old Aug 26, 2011 | 05:51 PM
apbt_2006's Avatar
Default 2000 Audi TT Possible Piston Rings Problems
I have a 2000 Audi TT Turbo. I recently replaced my head gaskets & had the cylinder head rebuilt. After i installed the cylinder head the car drove fine for about 1 day. After a week of having this done the car started to smoke out of the tail pipe. The smoke smells like oil & oil drips out of the exhaust. It smokes & drips a lot of oil from the exhaust. Im thinking that the piston rings are worn or broken. I did a compression test with the engine cold & these were my results:
Dry Test
Cylinder 1- 90 PSI
Cylinder 2- 85 PSI
Cylinder 3- 80 PSI
Cylinder 4- 82 PSI
Wet Test
Cylinder 1- 105 PSI
Cylinder 2- 110 PSI
Cylinder 3- 110 PSI
Cylinder 4- 105 PSI
What do you all think? Any suggestions are greatly appreciated.
Old Aug 30, 2011 | 09:56 AM
cincyTT's Avatar
I'm make believe
The engine has to be at temp for the numbers to mean anything. 120 is the min and all of them need to be within 10% from high to low.
You did use new head bolts correct as the stocks are not reusable?
Old Aug 31, 2011 | 12:50 AM
AudiGuest's Avatar
How positive are you on your timing job?
What color is the smoke?
Try draining some oil out of the pan. Is it black or milky colored?
Hockeymonkey
B7 Models
Aug 14, 2011 08:51 PM
yohan305
Nov 1, 2010 07:46 PM
91audi
Apr 18, 2007 11:27 PM
91audi
Apr 18, 2007 02:18 AM
91audi
Apr 18, 2007 02:01 AM
