2002 TT engine light after throttle body cleaning
Old 04-18-2013, 06:25 PM
skyhighhobby's Avatar
Default 2002 TT engine light after throttle body cleaning
so my RMP was Idling rough, i read if you clean the throttle body, it will fix the issue, so i opened it up the throttle body and cleaned it, it was super dirty, now my idle is perfect, but now, my engine light comes on and my turbo is acting up, not kicking in etc.
anyone have a clue what this could be? my turbo seems to work fine as i hear the whistle when warming up car, anyone any clue?
thanks
Old 05-01-2013, 10:59 AM
IronCobra53's Avatar
Do a throttle body re learn, if u moved the butterfly with the car off u probably threw it out of calibration, our throttle bodies are touchy. I'd do that before I touched anything else, a local shop might have the software to do it, or if u have vag com can do a relearn,
Old 05-14-2013, 02:56 PM
thanks for the reply,
so i found a very nice individual that has a vag.com
but he needs to know what code i need to do or what process is used to relearn the throttle body ( throttle body adapatation ) would you know what steps is needed for this?
ive never used a vagcom and he also does not know what the step is for the relearn, any idea? thanks again for your help
Old 05-15-2013, 02:21 PM
Lanessar's Avatar
This article should help.
Old 05-16-2013, 02:22 PM
thank you lanessar, that link is a great help, i will try this this week and reply back on how things go, as im sure others will encounter my same issues and would need a helping hand.
thank you
Old 05-17-2013, 10:16 AM
Lanessar's Avatar
No problem. Went through TB problems just a little while ago, and just happened to do the research, so you lucked out.
Old 05-21-2013, 10:05 PM
great, still havent done it but hopefully this week, did you get this done yourself or did a shop do it for you who had a vagcom? and how much did it cost you?
Old 05-22-2013, 09:25 AM
Lanessar's Avatar
I got it done at a local shop with a vagcom. It ran about $170 for labor on installation of a new TB (mine died) and the TBA. I believe it was $100 for the TBA.
Old 05-23-2013, 03:34 PM
170$ to install a new timing belt is very cheap, wow
Old 05-24-2013, 09:42 AM
Lanessar's Avatar
Sorry to burst your bubble, but "TB" is throttle body in this case.
Quick Reply: 2002 TT engine light after throttle body cleaning
