2003 TT glove box won't open...thoughts?
Old Jun 13, 2008 | 08:32 PM
phdpsy's Avatar
Default 2003 TT glove box won't open...thoughts?
Hmmmm...Any thoughts on causes of a glove box not releasing (seems to release on the left, but not the right)...yes it is unlocked. I've fiddled with it for 30 minutes and can't get it to open. Happened once before, but pushed it closed and it opened right up the next time. Any thoughts on cause/solution? Anyone know how it all goes together in case I have to take anything apart? Would appreciate realistic suggestions that don't involve explosives, bats, pry bars, etc.
Old Jun 13, 2008 | 08:43 PM
cincyTT's Avatar
I'm make believe
Default RE: 2003 TT glove box won't open...thoughts?
there is a problem with the hinge so you have to remove the side cover from the dash and push the tap in so the box drops open
Old Jun 13, 2008 | 08:44 PM
cincyTT's Avatar
I'm make believe
there is a how-to to fix it floating around on audiworld, but do be carful with the handle because it will break off
Old Jun 13, 2008 | 08:54 PM
phdpsy's Avatar
Thanks! ...I'll give it a try in the morning. I noted that the handle did not feel overly sturdy...so I'll be gentle.
Old Jun 13, 2008 | 09:00 PM
exTTreme's Avatar
My handle is broke off because of this reason once I got it open i used a piece of wire to make sure the right side pin doesnt lock it into place again
branstone
Dec 11, 2013 05:59 PM
jackson13
Sep 5, 2013 08:03 PM
Boojie_007
Mar 20, 2013 01:13 AM
vivekgupta
Feb 24, 2008 10:30 AM
flake
Jun 29, 2007 01:34 AM
