2Q's: can you adjust the power top and the turbo?
Just bought a bank repo, 03 TT quattro roadster with only 42,000km on it,
nice car but still reading all the forums, I have 2 little pet peeves I am trying to solve 1: my power top when I go to put up stops about six inches from the windshield locking frame... then I have to pull down hard to get it close enough to turn and lock into place... Is this normal or can I adjust to get it closer?? 2: you can hear the turbo start to wind up and kick in around 3,000 rpm's in every gear... seems a little quick to me, especially when I am coming off the lights in first.... can the turbo be adjusted and what is the normal band for a turbo TT still reading, but thanks in advance guys, |
Originally Posted by mrsats
(Post 1315976)
thanks for the info, just seems quick to me... but what is the normal band range for the turbo? 2500-3500 rpm's in your coupe or is it wider?
(Post 1316128)
btw i have a 180 thts why im runnin 11lbs of boost if u have a 225 it'll be higher around 15lbs i believe, hope this helps:cool: |
Following the thread about turbo and I have been wondering about my '02 TTQ 225 turbo system; I really don't know if it is actually working, power seems OK but I can't really hear anything like a turbo engaging or winding up. The only thing that I hear is when I shut the engine off, I guess it is the turbo that continues to run for several seconds. How can I tell if turbo is really functioning and is there any kind of real power surge when it does kick in. As for convertible top, 4 to 6 inches is where mine stops and I pull it down from there.
Originally Posted by Whitr
(Post 1316646)
And the sound u hear after u shut the car off is a pump tht moves oil through the turbo to cool it down, it gets rid of the need for a turbo timer, it shuts off after like 5 mins. hope this helps :cool: |
Thanks Iron Cobra for your input. My TT never has been a rocket, it is fairly peppy but I've never noticed any kind of a performance boost from the turbo, at least nothing like I thought a turbo would perform like. I may have had too high of an expectation.
Thanks again, Whitr |
(Post 1316936)
