3.2 Breaks
Old Sep 19, 2008 | 03:31 PM
Wintermute's Avatar
Default 3.2 Breaks
Has anyone ever put 3.2 breaks on their 1.8? Like OEM rotors & calipers? I noticed stock 1.8 rotors (solid not vented) are 312x25mm in the front 232x9mm in the rear. While 3.2 breaks are 334x32mm in the front & 256x22mm in the rear.
Old Sep 19, 2008 | 03:38 PM
cincyTT's Avatar
I'm make believe
all TT fronts are vented, just the 180 rears are solid where the 225's have vented. The cost for swapping either (f or r) will probably cost as much as a good front BBK and the rears just need good pads since they do only ~35% of the braking.
Old Sep 19, 2008 | 06:13 PM
Wintermute's Avatar
How much do 3.2 front calipers run for? I'm thinking this might be a cheaper BBK. Do the 3.2 come with vented front?
Old Sep 19, 2008 | 08:11 PM
Murderface's Avatar
I wouldn't call single piston calipers a BBK lol.
Unless I'm mistaken and they use R32 caliipers?
Old Sep 19, 2008 | 09:08 PM
Wintermute's Avatar
Well yea, it's no 4 piston.
Old Sep 19, 2008 | 11:10 PM
cincyTT's Avatar
I'm make believe
ALL TT FRONT BRAKES ARE VENTED! I dont know how much the setup would go for, but to put it into perspective, go look up the 225 rear brake upgrade and add another 20% atleast to that..... not cheap. If you want better braking, a $800 wilwood BBK is what you need
Old Sep 19, 2008 | 11:34 PM
warranty225cpe's Avatar
what would a Porsche bbk? What years/models are compatable? Can you use the tt hardware? I think that would be a better choice and you can go junk yard shopping
Old Sep 20, 2008 | 12:06 AM
cincyTT's Avatar
I'm make believe
Old Sep 20, 2008 | 12:40 AM
Wintermute's Avatar
Alright I believe you. They're vented.
Old Sep 20, 2008 | 12:41 AM
cincyTT's Avatar
I'm make believe
just wanted to make sure you saw it that time. Like said, you have an ALMS so you have f&r vented already.
