42 dd dp clunking noise?.....ecu upgrade problem?
Old Apr 28, 2009 | 07:48 PM
KingJames's Avatar
Default 42 dd dp clunking noise?.....ecu upgrade problem?
i just got my downpipe and intercooler installed today and there seems to be a clunking noise when i shift and there are low rpms? any idea?.......also i got my car flashed again after the install and now when i go passed 3500 the car wont go it will just rev up and when i get to 3rd gear it wont go at all just rev and when i try to punch it shuts down epc light turns on?????? any help?
Old Apr 28, 2009 | 09:33 PM
AWDrifter's Avatar
Dunno about the weird rev issue but the clunk is from your dp hitting the subframe. You need an ecs dogbone mount kit.
Old Apr 29, 2009 | 09:25 AM
KingJames's Avatar
where do they sell it?
Old Apr 29, 2009 | 03:03 PM
cmh's Avatar
cmh
They sell the ECS dogbone kit @ ecstuning.com
42draft also sells the dogbones I believe. I have the yellow, wich is the softest aftermarket available, after the initial break-in period I have no vibrations and no DP clunk.
Your DP might just need adjusting, but the dogbone is a worthy upgrade in its own right.
Old Apr 29, 2009 | 10:09 PM
myslow1's Avatar
i did the dogbone and my dp still vibrates and certain rpms... its really annoying. I think im going to take my car the an exhaust shop and see if they can do something to make it stop.
but dogbone SHOULD solve the problem.
Old Apr 29, 2009 | 10:50 PM
AWDrifter's Avatar
That is why the holes where you bolt the pieces together are ovals, so you can adjust it slightly.
der Lump
Dec 16, 2009 10:55 PM
jhsoccerodp
Nov 7, 2008 04:14 PM
AirMax95
Nov 2, 2008 10:12 PM
jessnjoe
Jul 31, 2006 02:02 PM
sandman
Oct 15, 2005 09:45 AM
