42DD 3" dp, 19mm Rsb on the way~
ORIGINAL: tom1222
Sounds like you either have a boost leak or are in limp mode. Or if you are still running the stock DV then the diaphram might be ruptured.
Do you hear any whistle sounds at accelleration? Let us know how the R1 works out. It should be about a 5 minute swap and should gain
you instant results.
ORIGINAL: gTT
I read from the forum that people suggested 19mm will be enough for the RSB if i will keep the stock front. (on quattro)
I will try to install the R1 this weekend and will let you know the result. I hope it will improve the boost.
My boost will not pass the 10, but vacuum at 19 when idle at normal temp.
wood_e
Sep 24, 2007 09:39 PM
