42DD dp, with stock cat back Yes/No?
ORIGINAL: gTT
I got the LED for license lights, pretty good. better then my burned out ebay LED. Whiter then others.
gy
ORIGINAL: Wintermute
Are any of the LED's for us TT's from 42?
gy
Which ones? Link me. Thanky you.
ORIGINAL: gTT
gy
gy
here
Size 39mm long x 11mm diameter
Available Colors White
LEDs per unit
Typical Applications VW license plate lights. These LEDs are built to handle 14.5
volts. Our standard 12v 39mm fuse style LEDs will NOT last
in VW license plate lights. These 14.5v versions are built to
handle the excess voltage and the heat.
when you order, tell them this LED for your :year: audi TT
they will make sure it will works for yours.
gy
Hey Take that down to advanced and they will hook it up. Next time just order it through them. I am going to get one next week for sure, what about the Milltek high flow cats are those an alternative to the 42dd DP.
I think you answered your own question, Mac.... they are just what they are twin hi-flo cats. The 42 DP is a sectional 3" pipe from the turbo to the cat-back with your choice of a hi-flow 3" cat or test pipe.
ORIGINAL: Mac_17
Advanced Audi? You know how much they charge for the installation?
ORIGINAL: jojoenglish85
will you throw a cell if you use the test pipe or is there still a place the o2 sensor?
The 1st O2 sensor is on the DP and the 2nd O2 sensor is after the cat/test pipe.
You may still throw a CEL with a testpipe but there is add'l hardware you can purchase to help with that. Try searching for angleblock or sparkplug anti-foulers.
