8 psi??
Old Jun 9, 2007 | 05:10 PM
303 tt's Avatar
Default 8 psi??
I have a quick question: i bought a 2000 tt 180 qt. the previous owner said it had been chipped with a mtm tune. i am ony hitting 8 lbs of boost?, from what i read, i should be hitting around 18 lbs?. I always assumed it had been chipped since i have no rev limiter. any thoughts?.
Old Jun 9, 2007 | 05:43 PM
cincyTT's Avatar
I'm make believe
Default RE: 8 psi??
well stock is 11psi and limp is 5psi. your kinda in a grey area. is there a mbc? if so, it may have then boost turned down.
Old Jun 9, 2007 | 07:42 PM
303 tt's Avatar
Default RE: 8 psi??
not that im awhere of?. wouldn't it be some where around the diverter valve?.
Old Jun 9, 2007 | 10:05 PM
cincyTT's Avatar
I'm make believe
Default RE: 8 psi??
most are, see it there is any other vac lines coming off the n75 (in the intake by the dv)
Old Jun 10, 2007 | 10:59 AM
303 tt's Avatar
Default RE: 8 psi??
cincy, there is nothing!, i just yanked the stock airbox out a couple of days ago, and replaced it with 1 of steve's at modshack. I don't get it?, could it be a ecu malfunction?.
Old Jun 10, 2007 | 12:33 PM
225tt's Avatar
Default RE: 8 psi??
Boost leak, bad wastegate there are alot of differnt things, are you sure the gauge is hooked up correctly. Someone else had a problems and it turned out he hooked his boost gauge into a boost line that wasnt as good as some others.
Old Jun 10, 2007 | 12:43 PM
303 tt's Avatar
Default RE: 8 psi??
there's more than 1 boost line?. the gauge seems to be working fine, i've got vacuum at about -15, and the boost holds solid all the way through the rpm's. so no leak then right?.
Old Jun 10, 2007 | 12:55 PM
225tt's Avatar
Default RE: 8 psi??
Where is your gauge hooked into? How is the line itself to your guage? Also no not necessarly you wont have any boost leaks at lets say 5psi because its not enough pressure to leak out but the higher the pressure can open leaks that you never thought were ever there. Does that make sense?
Old Jun 10, 2007 | 01:04 PM
303 tt's Avatar
Default RE: 8 psi??
it does, thanks man!. so how do i check for leaks?.
Old Jun 10, 2007 | 01:19 PM
225tt's Avatar
Default RE: 8 psi??
The 1.8T forum on Vortex under the FAQ for 1.8t engines has a leak DIY writeup check it out.
