911 HELP Service light on
Old Jan 25, 2008 | 12:12 PM
datdonnguyen's Avatar
Default 911 HELP Service light on
hey anyone know wtf is going on i just change out my O2 sensor and the check engine light went off spent 400. on this repair. the Fing thing just turned back on 1 day later. the mech told me now i need to fix my water temp sensor coast 600. I'm i getting hosed? HELP
Old Jan 25, 2008 | 12:16 PM
techbod's Avatar
Default RE: 911 HELP Service light on
coolant temp sensor its called, whats the fault code because its important
Old Jan 25, 2008 | 12:19 PM
techbod's Avatar
service light? ill have to check into reset
Old Jan 25, 2008 | 01:04 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: datdonnguyen
You are totally being hosed!! The o2 is $80-120 and then takes all of 1 hour to change and thats another $60-100 in labor. Plus without codes, he is just changing things blindly. As for the coolent temp sensor, its a $20 part and takes 10mins to install. Its a very simple how to. I would first take it to autozone or some parts store and have the give you the codes it throwing. Until then, you are just spending money. I would try to recoup some of your money for the o2
Old Jan 25, 2008 | 02:11 PM
the code is p0441 now i got the code reader and that is the only thing wrong at this point. I also got and air to fuel meter want to hook it up but where do i start. i figure i was getting hosed but i need to pass emmisions to get register. lesson learned. thank all
Old Jan 25, 2008 | 02:34 PM
beachchair's Avatar
P0441 = Incorrect Purge Flow - EVAP Emission Control System
Old Jan 25, 2008 | 02:36 PM
cincyTT's Avatar
I'm make believe
go here and put it in and see whatcould be wrong.The mainis the sai (secondary air injection). it could either have a hole in the plastic tubing, vac line problem to the combi valve attached to the head or the pump is dying.
Truthteller
May 2, 2008 10:20 AM
Lena
Dec 15, 2006 09:59 AM
impaler2383
Dec 8, 2006 06:10 PM
Rikter
Aug 20, 2006 08:48 PM
audisales
Sep 7, 2004 12:15 PM
