About DVs...
Old Dec 10, 2007 | 11:25 PM
DEDMN_TT's Avatar
Default About DVs...
So I got myself a Froge DV and installed it. For some reason my car isn't as aggressive as before. (less pull it seems like, slower acceleration, etc) I read there are different springs you can change inside the DV. I'd write the boost info but I'm still waiting on the vent ring to come in so I can install my Boost Gauge. I guess what I'm asking is how do I know which spring to change to? The forge box didn't really come with a manual. My new DV is just sitting as a paper weight right now since I like how the older plastic DV feels.
Another one, had a chip in my car's glove box when I bought it with the markings "AMD" on it. I had a feeling it was a clue that my car had already been chipped. I took it to the shop and showed one of the guys and said, yes that was the old factory chip. How do I find out what chip I have now? Is it hard to get to the guts of the computer?
thanks for any info.
Old Dec 10, 2007 | 11:29 PM
cincyTT's Avatar
I'm make believe
Default RE: About DVs...
the green is for stock and yellow if chipped. If you use to soft of a spring your probably leaking some boost and thus having your problems.
Please tell me its not one of THESE chips
Old Dec 10, 2007 | 11:34 PM
TT_GUY's Avatar
most likely its a computer chip...haahaha but yeah i just recently installed a forge 007p , didn't feel much difference but just installed a boost gauge a few days ago...im spiking at 11 and holding at 9psi...i got a 00 TT 180Q...i wonder if i should change the spring too..
Old Dec 11, 2007 | 12:24 AM
DEDMN_TT's Avatar
I didn't know audis were tiburon inside! whoa! but really, it's more like this:
Old Dec 11, 2007 | 12:35 AM
TT_GUY's Avatar
atleast u can say ur modded now..with a chip...hahaha, but what kind....hmm.
Old Dec 11, 2007 | 08:36 AM
Burzum's Avatar
ORIGINAL: TT_GUY
Isn't that kinda bad? I thought the 710Ns that come with your car were rated for 18psi. I just put a couple of those in my GIAC'd S4 and they're holding boost great.
Old Dec 11, 2007 | 09:38 AM
patty AT forge's Avatar
Green - 5-15 PSIYellow - 15-23 PSIBlue - 23-30 PSIRed - 30 + PSI
Those are rough figures.
Also try the "pen-test" in this pdf: http://www.forgemotorsport.com/media/valve(1).pdf
Which port on the valve did you connect to the turbo inlet pipe?
Old Dec 11, 2007 | 11:17 AM
.clipse's Avatar
SoCal Crew Member
only change your DV spring if your boosting higher than stock (chip/diode mod/etc.)
lol @ AMD making the stock chips for the TT. overclock time!
Old Dec 11, 2007 | 12:32 PM
Grooby's Avatar
watercool the chip, bump up the voltage, and OC it!
Old Dec 11, 2007 | 04:04 PM
achTTung's Avatar
I'll take a pic of a physically chipped ECU this weekend.
Still have the ECU from my 180, from memory, thats not quite what the chip looks like, that looks too big, but it HAS been a while since I had that ECU apart, I may be wrong.
I also have a stack of old EPROMs that were harvested from some old *** computers, you may have been blessed by a similar POS chip.
