AC not working....Interesting case
Old Aug 28, 2013 | 03:24 PM
MeganFrai's Avatar
Default AC not working....Interesting case
A little bit ago my AC crapped out, and when we finally took a look at what the problem could be, we fixed it by replacing the High pressure switch and disconnecting the battery for about ten minutes.
THEN being that I live in florida and employers like to make you come in despite flood warnings, my car flooded out, water up to the exhaust, HOWEVER would still turn on once out of water.
BUT after this whole thing happened the ac no longer works, and being that I now live in Souther Cali...its hot and..i want my damn ac back haha.
ANY suggestions as to what i could possibly check or that could be the problem aside from fuses would be appreciated!
thinking about going out and buying a new high pres switch becuase i tried taking it off and it made a pop. not sure if that pressure releasing would damage it, its brand new, but. let me know!
Old Aug 28, 2013 | 07:22 PM
ericcota2003's Avatar
I just noticed that this a second post from you and I would say to start with the fan problem....Im starting to think based on the fact that your ac isnt working at all either its your fan control module. When you turn the AC on the fans are supposed to kick on to force air to flow over the radiator which also starts the A/C. No fans, no AC, overheating....I would get this fixed asap before going to far and I may suggest throwing a new thermostat in just to make sure that hasnt seized up on you as well.
Old Sep 1, 2013 | 10:51 PM
MeganFrai's Avatar
THANK YOU so much for your reply. much appreciated :]
bliggity
Oct 11, 2007 09:16 PM
vollgas
Aug 11, 2006 02:40 PM
99a4audi
Dec 15, 2004 04:33 AM
