Adjusting Konis
Old Dec 17, 2007 | 01:35 AM
Skipponator's Avatar
Default Adjusting Konis
I installed Koni adjustable struts and H&R lowering springs, and I was able to adjust the firmness with the supplied **** with the strut out, but after install, I cannot. I broke my Koni adjuster ****, I have tried a crescent wrench, and still, no luck, this is with the car on the ground, I have not tried it lifted. I have it set on the softest, but I want to see how it is stiffer. Can these be adjusted while installed? Also, the rears, why are they stamped adjustable, but nowhere to adjust them? Thanks!
-Skip
Old Dec 17, 2007 | 01:36 PM
kgoch's Avatar
Default RE: Adjusting Konis
The rears you have to remove to adjust. They must be compressed completely, then turned.
adam044
Aug 2, 2014 11:33 AM
dale55
Jul 15, 2010 10:14 AM
nrowensby
Jun 4, 2008 08:57 PM
dale_gribble
May 7, 2008 10:09 PM
Scottykenneth
Jan 26, 2008 07:49 PM
