Air Pump Hose
Old Jul 21, 2007 | 10:14 PM
Mobius97's Avatar
Default Air Pump Hose
Well I installed a boost gauge, put in the Forge splitter and installed a new intake. Everything was going fine until I went to hook the air pump hose to the heat shield of the intake.......I pulled up andout came the air pump hose. I jacked the car up looked underneath, touched the other air pump hose and that one broke too, both at the clamp that hold them in place. I went to NAPA and grabbed some heater hose shoved it into the existing hoses and clamped both sides down. Is there a lot of pressure going thru these hoses what do you folks think of this fix?
For those with a chipped 225.....the splitter valve, I turned it about 13 clicks clockwise. The directions aren't very descriptive....mine never rattled even when I turned it counterclockwise all the way at the start as instructed. Suggestions?
Old Jul 22, 2007 | 06:36 PM
cincyTT's Avatar
I'm make believe
Default RE: Air Pump Hose
ORIGINAL: Mobius97
Well I installed a boost gauge, put in the Forge splitter and installed a new intake. Everything was going fine until I went to hook the air pump hose to the heat shield of the intake.......I pulled up andout came the air pump hose. I jacked the car up looked underneath, touched the other air pump hose and that one broke too, both at the clamp that hold them in place. I went to NAPA and grabbed some heater hose shoved it into the existing hoses and clamped both sides down. Is there a lot of pressure going thru these hoses what do you folks think of this fix? I found the person before me use duct tape to fix it and i was pissed. I have it the same way as you now and it has been good for about a year now
For those with a chipped 225.....the splitter valve, I turned it about 13 clicks clockwise. The directions aren't very descriptive....mine never rattled even when I turned it counterclockwise all the way at the start as instructed. Suggestions? Start off about 10 clicks clockwise and continue to tighten it until you see full boost and no flutter. You want it soft as possible without losing boost
Old Jul 22, 2007 | 06:37 PM
shkenned's Avatar
So question: should I mess w/ my DV a little also? I've never tried turning it, but after installing my MBC it seems like I may be losing some.....just sounds like a small constant "pshhhhhhhhhhhhhh" until I completely dump it.
Old Jul 22, 2007 | 06:39 PM
cincyTT's Avatar
I'm make believe
should be fine for your stock car until your chip is in. then you will need to move to the next spring and maybe a shim/washer
Old Jul 22, 2007 | 06:40 PM
shkenned's Avatar
Sounds good, hopefully that'll be by weeks end! (i'm pretty excited)
Old Jul 22, 2007 | 06:45 PM
racer_x's Avatar
cincy, do you like the washer shim trick?
I'll have to cut the clamp to my DV to get the hose... I don't suppose I can zip-tie?
cincyTT's Avatar
I'm make believe
i figuredwhen i saw the thread
Old Jul 22, 2007 | 06:48 PM
neur0tic's Avatar
the hose on the DV usually just slides off and on even with the clamp on it. mine still has the factory clamp on it and I've pulled it quite a few times.
Old Jul 22, 2007 | 06:49 PM
racer_x's Avatar
ORIGINAL: cincyTT
i don't follow?
Old Jul 22, 2007 | 06:50 PM
racer_x's Avatar
mine's pretty snug... I'll pull at it though, never hurt anything except my back, lol
