Are all MAF's the Same?
Old Jun 26, 2007 | 11:19 AM
theTTkid's Avatar
Default RE: Are all MAF's the Same?
since we are all talking about this whole MAF situation... mine is fine... stock.. What are peoples views on the modshack ****? thanks a bunch
Old Jun 26, 2007 | 11:26 AM
techbod's Avatar
codes is the point ( MAFs are sometimes changeable ) and the last letter probably means date of/factory/place
Old Jun 26, 2007 | 11:36 AM
rapbap31's Avatar
This is what I meant. Not the letter code at the end. This may be nothing but then again, why wouldn't bosch sell the same part number? Am I just overanalyzing the situation and maybe should be looking at something else causing this?
BOSCH Part # 0280217117 - 2001 1.8t B5
BOSCH Part # 0280218063 - 2002 1.8t B6
Old Jun 26, 2007 | 11:40 AM
theTTkid's Avatar
**** anyone?
Old Jun 26, 2007 | 11:44 AM
techbod's Avatar
the part number changes with the manufactures date/time/place and set to country requirements for emissions but that's it so depending on the law where you live the settings could differ
Old Jun 26, 2007 | 11:53 AM
rapbap31's Avatar
I guess that knowing there were some changes from '01 to '02, that some of the electronics may have changed.....was hoping for a bad MAF sensor and an incorrect replacement.....
Old Jun 26, 2007 | 12:01 PM
techbod's Avatar
very possible but it depends on who fitted it and the experience ( it can be re-programed with VAG ) set up with it, im basing my experience on the older systems which I took apart and set them up for the modifications
Old Jun 26, 2007 | 12:12 PM
  #18
rapbap31's Avatar
well can you offer some advice on programming, because if thats the case I may have caused a more indirect problem. At this point, I have swapped them back and forth 2-3 times to see which performs better and after I had them read the CEL light. I didn't even know it the car had to be re-programmed after swapping a map sensor
Old Jun 26, 2007 | 12:17 PM
  #19
techbod's Avatar
im not going into the newer ones but the older was just a better resistor ( not the eBay type )
Old Jun 26, 2007 | 12:26 PM
  #20
techbod's Avatar
sad to say the newer ones need a remap
