Annoying sounds after 42dd and install-225
Old Jul 22, 2009 | 07:06 AM
Patman's Avatar
Originally Posted by 71custom
Could it really be the cat? The cat is the one that came with the 42DD kit, and it looked fine when I pulled it off.
There were pieces of what appeared to be ceramic in front of the cat that were bouncing around,...
Where would those pieces you removed come from if not the cat? How would they get there if not from the core? Would they have not made noise and/or fallen out if they were there when you pull it out of the box? There are such things as manufacturing defects so it's possible the cat just happened to be flawed and failed after some use. It's possible you banged it on something, it doesn't take much. No matter, it's worth looking in to further because if everything is tight and properly gapped that's a prime suspect based on the pieces of the puzzle so far.
Old Jul 22, 2009 | 12:34 PM
warranty225cpe's Avatar
Go with a test pipe to see if the noise goes away.
Old Jul 22, 2009 | 03:51 PM
carhopper's Avatar
Will you sell me your stock down pipe? Mine has a tear in the flexible piece.
Old Jul 22, 2009 | 07:42 PM
AWDrifter's Avatar
First time I fit my 42dd dp i had it too high under the car and it rattled / buzzed against the heat shield
Old Aug 12, 2009 | 11:42 AM
71custom's Avatar
Member
Okay, I'll be pulling the section off and looking at it again. However, I'm still getting the CEL from the rear O2 sensor. I've tried no spacer, 1 spacer, and 2 spacers, and still get the same code for the sensor.
Old Aug 13, 2009 | 07:32 AM
carhopper's Avatar
What CEL are you getting? If it is P1114 "resistance too high" or P140 "no activity" or P1118 "B1 S2 open", you likely damaged the sensor when removing from the old pipe. I was very careful and still damaged mine. It was tough to get off, even with a 12" breaker bar so the extreme twisting damaged the internals. I replaced with the Bosch universal 4 wire and no more problems.
Old Aug 17, 2009 | 02:56 PM
71custom's Avatar
Member
I can't remember the code, but it wasn't either of those. Does anyone have any experience with an O2 simulator? I'm thinking I may just go with one of those.
AWDrifter
Apr 3, 2009 03:11 PM
THEPARTSMAN10
Aug 15, 2008 01:07 PM
oczalevsevy
Jan 11, 2008 10:20 AM
