Another suspension post
Old Feb 20, 2008 | 03:22 PM
randomloginname's Avatar
Default Another suspension post
As is sometimes the case on this forum, here is a ramblinb rant and a question.
My parts are finally all in, ie dogbone nushings, koni fsd w/eibach springs, neuspeed front and rear asb's, strut mount bearing/bushings. So thats all cool, unfortunately cant get down to shop till next Thursday, and I have an alignment set up for the next day, so again all set there, though I wish it was sooner.
My cars got 85-86k, is there any value in the removed rear sway or front dampers or should I just have the tossed? My front sway is trash now as are my rear dampers, thus the upgrade.
Only other upgrade news is that Matt was able to pull my rear driver abs sensor as giving intermittent singals, the cause behind my intermittent abs light, so I will try and get that cleaned up. Also, I put on the shroom and a breather, along with the low profile engine bay trim from earlier, sounds cool.
Old Feb 20, 2008 | 03:50 PM
eliTTe's Avatar
Default RE: Another suspension post
mine are still sitting at my parents house, probably end up throwing them out... or making them into a clock(Nate knows what I mean)
Old Feb 20, 2008 | 04:09 PM
cincyTT's Avatar
I'm make believe
Idle hands my friend, idle hands.
You can always try to sell whats good in the classifieds for cheap. You wont make much, but you should be able to get some money for them and help someone out if they dont want to upgrade.
Old Feb 20, 2008 | 07:25 PM
Thanks....will do
Euro Dreams
Dec 6, 2019 03:38 AM
luxuryimports1
Jun 23, 2009 11:11 AM
