anti-freeze required?
Old May 11, 2006 | 05:46 PM
clayton787's Avatar
Default anti-freeze required?
I have a small coolant leak somewhere. Until I get the time to run it down, I need to add a little anti-freeze to the system. Audi says I have to use their special brand ($27 for a gallon). Any body know whether this is true?
2000 TT 185 HP
Old May 12, 2006 | 12:36 PM
Jestnomen's Avatar
6th Gear
Default RE: anti-freeze required?
VERY true. Do not use anything other than the pink Pentosin G12.
Old May 12, 2006 | 06:08 PM
aTiTude's Avatar
My dealer said that if in an emergency you can run the Prestone that states on the bottle that it is compatable with any vehicle. Its a yellow jug. (if that helps) Anyway he said that would be fine for a quick fix, however you need to get it to a shop fairly quickly afterwards so the system can be flushed and the fluid replaced.
crazyone
May 15, 2011 11:30 PM
zblad
Jan 18, 2011 01:59 PM
Collinsd
Jan 8, 2009 11:21 AM
ironman
Apr 19, 2007 01:34 PM
Dj Spiel
Oct 17, 2005 04:17 PM
