Old Mar 28, 2010 | 03:00 PM
spiderhole's Avatar
Default Audi TT
Hey guys,
Picked up this car a while back. I do 95% of my own service and I want to keep up with the intervals on maintenance and know what to watch for. This isn't my first Audi, and I currently also service my 2000 Land Rover, 88 K1500 Chevy, and 2008 BMW 335xi.
I've already changed out the oil using Mobile-1 0-40 euro. The filter was kind of a pain in the butt, and it doesn't seem like these engines have much oil capacity?
At what point should I do the timing belt? Anything else I should monitor and inspect?
Thanks
Old Mar 28, 2010 | 04:25 PM
ericgl's Avatar
General consesus is start thinking seriously @ 60K. Mine was replaced at 62,000.
Old Mar 28, 2010 | 07:50 PM
lennyauditt's Avatar
along with the Timing belt (TB) you need to watch the water pump. Not 100% sure on the '06 models but they use plastic blades in the water pump and they can fail and cause problems . But around 60K you should change the water pump and TB . could even do it earlier to avoid problems .
if the TB breaks or fails.. you will be rebuilding the top end of your motor .
Old Mar 28, 2010 | 07:56 PM
spiderhole's Avatar
$2500 later in my 2000 A4 I found out what happens when the timing belt fails the hard way!
Old Mar 29, 2010 | 08:08 PM
yeah i hate em !
i need to learn how to change em out
