Automatic Window's
Old Jan 3, 2007 | 02:15 AM
moeron7's Avatar
Default Automatic Window's
I just bought a 2002 TT225, and I cant roll down my passenger side window with the driver side controls. Is this normal or do i need to get that fixed?
Old Jan 3, 2007 | 02:18 AM
DenimTT's Avatar
Default RE: Automatic Window's
You need to get that fixed. Could be as simple as a switch, or its could be a motor or regulator issue.
Old Jan 3, 2007 | 02:20 AM
moeron7's Avatar
Cool thanks, its probably just a switch cause the thing doesnt even move. I can make it go up, just not down.
Old Jan 3, 2007 | 12:15 PM
BlackRaptor's Avatar
My windows are on crack they will go down but sometimes stop half way they will go up but sometimes half way they will stops and start going down instead haha.
Old Jan 3, 2007 | 02:09 PM
Palindari™'s Avatar
Yeah, freaking gremlins - there's a way to reset the controls, think XCR8TT knows, can't find the post that cover this before- mine does it off and on. One moment they all work fine then I go 3 weeks with the driver's sidenot doing the auto close or open - then it will work but then the passenger side won't move at all... so on and so forth.
For now I just kinda roll with it... lol
Old Jan 3, 2007 | 03:20 PM
The TT is the master of gremlins.
My fav is the blinkers turning off all interriorpower the tach goes dead the radio goes dead the needles drop to 0 haha.
I got it fixed but boy this car has gremlins. My 02 180TT i had before this had them too.
Old Jan 3, 2007 | 03:21 PM
XCLR8TT's Avatar
Did I hear my name mentioned????
Power Window Convenience Feature Reset
1. Close the window completely by lifting the power window switch and holding.
2. Release the switch and then lift it again for a second.
The convenience feature is now activated.
Old Jan 3, 2007 | 04:34 PM
moeron7's Avatar
Thanks, but my problem is i cant roll the passenger window down from my driver side control. I can only roll it up.
Old Jan 3, 2007 | 04:42 PM
I would guess you have a bad switch then.
Old Jan 3, 2007 | 05:00 PM
XCLR8TT's Avatar
It is more than likely your switch. It's not too bad a job to replace. Once you remove the door panel, it takes just a few minutes to swap the switch out.
