Bad Cat
Could a bad cat cause a car to only run on 2 cylinders and be all putty.
RE: Bad Cat
a putty-cat. bahhaha :D
RE: Bad Cat
No, a cat just heats up the exhaust gas to burn all the fuel.
IF your running on 2 cylinders you have either: bad plug bad coilpacks a cracked/damaged coilpack harness |
RE: Bad Cat
ORIGINAL: cincyTT No, a cat just heats up the exhaust gas to burn all the fuel. IF your running on 2 cylinders you have either: bad plug bad coilpacks a cracked/damaged coilpack harness |
RE: Bad Cat
That is usually an o2 code i believe, you need to get the actual code to find out more.
But if you have missfires in just 2 cylinders and not all of them, you should have something listed above along with a bad o2 and /or cat |
RE: Bad Cat
ORIGINAL: cincyTT That is usually an o2 code i believe, you need to get the actual code to find out more. But if you have missfires in just 2 cylinders and not all of them, you should have something listed above along with a bad o2 and /or cat |
RE: Bad Cat
heneeds codes. running on 2 cylinders would mean plugs/packs/wiring and the code seems like a o2 problem
RE: Bad Cat
YEah I cant get the actual codes cause his buddy who pulled them wont give themto him to give to me for some reason. Its pretty lame!
RE: Bad Cat
what an a-hole. i dont get that one.
RE: Bad Cat
just go to the auto parts store and get you a set of 4 NGK bkr7e plugs and replace them, cheap and easy, then you can go from there
