Bad Cat
Old Jul 31, 2007 | 01:33 PM
moeron7's Avatar
Default Bad Cat
Could a bad cat cause a car to only run on 2 cylinders and be all putty.
Old Jul 31, 2007 | 01:35 PM
.clipse's Avatar
SoCal Crew Member
Default RE: Bad Cat
a putty-cat. bahhaha
Old Jul 31, 2007 | 01:36 PM
cincyTT's Avatar
I'm make believe
Default RE: Bad Cat
No, a cat just heats up the exhaust gas to burn all the fuel.
IF your running on 2 cylinders you have either:
bad plug
bad coilpacks
a cracked/damaged coilpack harness
Old Jul 31, 2007 | 02:16 PM
moeron7's Avatar
Default RE: Bad Cat
ORIGINAL: cincyTT
bad plug
bad coilpacks
Ok if that was the issue, would it also throw a code about a bad "cat on bank 1" or something like that? As well as misfire codes.
Old Jul 31, 2007 | 02:34 PM
cincyTT's Avatar
I'm make believe
Default RE: Bad Cat
That is usually an o2 code i believe, you need to get the actual code to find out more.
But if you have missfires in just 2 cylinders and not all of them, you should have something listed above along with a bad o2 and /or cat
Old Jul 31, 2007 | 02:41 PM
moeron7's Avatar
Default RE: Bad Cat
ORIGINAL: cincyTT
Could the bad plugs/coil packs cause the cat or o2 sensors to go bad or vice versa? I dont wanna get a new cat or o2 sensorsif its justbad plugs/packs. I guess I can take the plugs out and see how those look. Also how do you tell if a coil pack has gone bad? FYI-this isnt on my car,just helpin a buddy out.
Old Jul 31, 2007 | 04:13 PM
cincyTT's Avatar
I'm make believe
Default RE: Bad Cat
heneeds codes. running on 2 cylinders would mean plugs/packs/wiring and the code seems like a o2 problem
Old Jul 31, 2007 | 04:57 PM
moeron7's Avatar
Default RE: Bad Cat
YEah I cant get the actual codes cause his buddy who pulled them wont give themto him to give to me for some reason. Its pretty lame!
Old Jul 31, 2007 | 05:43 PM
cincyTT's Avatar
I'm make believe
Default RE: Bad Cat
what an a-hole. i dont get that one.
Old Jul 31, 2007 | 07:06 PM
eliTTe's Avatar
Default RE: Bad Cat
just go to the auto parts store and get you a set of 4 NGK bkr7e plugs and replace them, cheap and easy, then you can go from there
