Bad Turbo???
Old Jan 21, 2009 | 11:05 PM
bvgoosedd's Avatar
Wink Bad Turbo???
OK so i think i blew up my turbo. i was running around 23 psi outta it, with the mbc. now it doesn't go past 15 and it keeps jumping around. like 10psi and then 15psi and then like 5psi. also i hear like a whine, sounds like a supercharger. and no power well no where near what it had before. ofcourse i know it's cus of the psi. i have no check engine lights on or anythin. so i think it's the turbo. What do you guys think?? So i've been looking and i only have $2000 to spend right now. the only thing i can find is the gt2871r eliminator kit. i wanted to know if all i need is that tho. cus it says it's a replacement for my k04. so i'm sure i have to get my car flashed but is there anythin else i would need? and is that the best way for me to go???
HELP!!
Old Jan 21, 2009 | 11:16 PM
theTTkid's Avatar
if you blew your turbo youd get nothing... i would start with checking for vac/boost leaks. 15psi out of a blown turbo i think not. thats more than stock.
and dont get an elim...
Old Jan 21, 2009 | 11:19 PM
cincyTT's Avatar
I'm make believe
boost leak tester will show any leaks. If none is found, pull the tip and check for play in the turbo.
Old Jan 22, 2009 | 12:06 AM
Murderface's Avatar
Supercharger noise usually means your turbo's toast but check to make sure it's not a boost leak first..
Old Jan 22, 2009 | 01:35 AM
myslow1's Avatar
http://www.youtube.com/watch?v=NJRAfFirdYI
if it sounds like this ur turbo is poo poo. otherwise look for a vac leak.
PS. the guy talking cracks me up every time i see this video
Old Jan 22, 2009 | 01:47 AM
Murderface's Avatar
lmfao @ the cameraman.
Old Jan 22, 2009 | 01:48 AM
myslow1's Avatar
http://forums.vwvortex.com/zerothread?id=4190241
if you are wanting a stock replacement you can PM this guy he has one fs
Old Jan 22, 2009 | 10:09 AM
bvgoosedd's Avatar
mine sounds almost as loud as the youtube video. not as loud tho. if it is the turbo i don'
t want to buy a stock turbo cause i was gonna go with a big turbo. so what should i go with. rite now i have $2000. or i can save for the summer it has to be done by the summer. and the car will hit 15 psi but die down real quik like it struggles to get to the 15 and then dies. if it was that bad of a leak wouldn't i have a chieck engine?
Old Jan 22, 2009 | 10:57 AM
cincyTT's Avatar
I'm make believe
dont really get a cel unless it keeps happening for a long period of time or the couple gos loose. Still would build a pressure tester or have it done somewhere
Old Jan 23, 2009 | 01:38 AM
bvgoosedd's Avatar
i called pagparts and they said they'll get me a gt2871r kit for 4500 with everythin i think that is what i'm gonna do. i looked everything over as far as the hoses. i know looking isn't enough but the way it happened kinda just tells me it's the turbo and the sound that it makes. and it kinda got worse and worse as the sound got worse and worse. if that makes sense. i don't have a compressor so i really wouldn't know how to presure test it. and this place in my town is gonna charge me 100 to test it. Now i just gotta save. hopefully in two months.
03a418tnate
Aug 10, 2010 08:07 PM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
