bolt on grounding wires....help
Old Feb 2, 2008 | 04:27 PM
  #21
zero388's Avatar
Default RE: bolt on grounding wires....help
I tried that and still no luck. If anyone has any other ideas or if you hace the AWE gauge let me know how you wired it. thanks.
Old Feb 2, 2008 | 04:28 PM
  #22
Red_sapphire89's Avatar
i gotta work from 7-1am tonight but after tht i will make a write up with pics and a video...
Old Feb 2, 2008 | 04:29 PM
  #23
zero you gotta plug the harness back in with the wires firmly attached or they will not come on. also make sure the fog lights are off
Old Feb 2, 2008 | 04:49 PM
  #24
zero388's Avatar
come on, anyone with the AWE gauge?
Old Feb 2, 2008 | 05:21 PM
  #25
zero388's Avatar
Default RE: bolt on grounding wires....helpAWE Boost gauge
help. Does anyone know what I am talking about with the grounding wires?
Old Feb 2, 2008 | 06:31 PM
  #26
zero388's Avatar
ok well it lights up and looks really nicebut when I drive it doesnt do anything....[:@] The vaccum line is clear and set up as it should be.
Old Feb 2, 2008 | 06:56 PM
  #27
ouTTie914's Avatar
AWE boost gauge write up
Old Feb 2, 2008 | 07:07 PM
  #28
zero388's Avatar
I have done everything to do everything is hooked up properly as far as I can tell from the instructions. But when I turn the car on the gauge stays at zero, when I backout it is still at zero, and when I start to drive it is still at zero. The only thing I can think of is that there is something wrong with the vaccum line but I double checked it and cannot find anything. Anyone have any ideas as to why it isnt working?
Old Feb 2, 2008 | 07:14 PM
  #29
ouTTie914's Avatar
What vac source did you use?
Old Feb 2, 2008 | 07:15 PM
  #30
zero388's Avatar
My vac hose is connectedto the FPR if thats what your asking.
