bolt snapped off from top of strut tower!!
ok i went to check up on it again...
i found was the 'cup' , 1 nut and very fine metal shards and shavings... hmm..
i stuck my finger into the damage hole in my coilover and felt somthing loose. sounds funny but it's not a very funny situation
I'd be on the phone with Vmaxx
Call and see about getting a replacement.
I wouldn't mention hitting a bump at all, sounds like normal driving anyway and that's just another excuse they will use.
besides, the bump shouldn't have been the problem. it's my daily driver. i go through that bump/groove in the road at the same speed as all the other cars, 5 times a week.
so i can negate that area being the cause. and there are alot worse bumps out there than that~
The driver side pic (4th from the top) looks like the nut is stripped. On the passenger side it looks like you only have a couple threads engaged on the nut. When I had my stockers in and now with my bilsteins the top of the strut threads all the way through the nut and there are 5 threads or so coming out the top. Maybe you didn't tighten them down enough. Or maybe your coilovers just have a shorter threaded section at the top.
