boost
Old Oct 26, 2007 | 01:47 PM
wezal's Avatar
Default boost
so i put in a boost gaugelast weeekend ( pictures coming soon) and as far as i know my car's ecu isstock. i usually stay around 10 or 12 psi but if i get on it i can get it up to 15 and have hit 18 a cupple of times. i was just wondering if this is a spike in boost or something i should be worried about?
Old Oct 26, 2007 | 02:03 PM
cincyTT's Avatar
I'm make believe
Default RE: boost
sounds like chipped to me. you wouldnt get to 18psi with a n75, maybe 12-14psi, but never over 1bar
Old Oct 26, 2007 | 02:19 PM
diehlryan's Avatar
Default RE: boost
ORIGINAL: cincyTT
I would think 18psi on a stock ecu would def = limp mode.
maybe there is a leak somewhere keeping you close to stock boost most of the time. ??
Old Oct 26, 2007 | 03:01 PM
wezal's Avatar
Default RE: boost
if it was chipped how would i tell if it was?
Old Oct 26, 2007 | 03:41 PM
DurTTy's Avatar
Default RE: boost
maybe you mentioned this already, but what car do you have 180TT QC non QC or do you have 225TTQC ?
Old Oct 26, 2007 | 03:54 PM
wezal's Avatar
Default RE: boost
ive got a 225ttq roadster
Old Oct 26, 2007 | 05:31 PM
225tt's Avatar
Default RE: boost
Could be chipped, or you could have a crappy gauge (just saying), does it just flash up to 18 or does it kinda hold and then slowly fall off?
Old Oct 26, 2007 | 11:11 PM
wezal's Avatar
Default RE: boost
its a stewart warner gauge it seems like it is good quality, it only hit 18 a cupple times and would stay for a second and go down to 10 or 12 psi.
Old Oct 26, 2007 | 11:16 PM
cincyTT's Avatar
I'm make believe
Default RE: boost
just watch it a couple of days since it seems low for a chip and to high for stock. Give it a vary of conditions and see what happens. BTW, where did you tap in the gauage at?
Old Oct 26, 2007 | 11:58 PM
wezal's Avatar
Default RE: boost
I tapped the vaccum line that goes the the fpr.
