boost controller question
Old Aug 18, 2007 | 07:46 PM
TTsteve's Avatar
Default boost controller question
with a chipped 08 tt I think Im running about 18-20 psi (?). Would a manual boost controller give me better results even with the chip software? I havent hooked a BC up yet to see if the boost drops alot or not at hugher rpms but would a bc help keep my boost longer even with the K03 it uses?
Old Aug 18, 2007 | 08:23 PM
cincyTT's Avatar
I'm make believe
Default RE: boost controller question
yes it will spool faster and hold longer. Just dont install it until you have the gauge installed.
Old Aug 18, 2007 | 09:07 PM
TTsteve's Avatar
cool, with the chip the car really pulls hard but seems to drop some at higher rpms. Hookup the same as with the 1.8? Do you know what psi I should set it for? Not sure what the boost level is for the 2.0 w/GIAC.
Old Aug 19, 2007 | 10:56 AM
TTsteve's Avatar
So is a BC bad for the engine with only a chip? Audiworld guys seem to think so. If Im not trying to boost more than the turbo can handle but just make it hold longer I would think it would be fine. But not sure and I dont want to hurt the new baby. Thanks.
Old Aug 19, 2007 | 11:50 AM
theTTkid's Avatar
like cincy said, as long as you have your boost gauge installed so you can make sure you dont put too much on the ko3 you shuold be fine... id wait for him to respond though even though im almost positive it would work even with just a chip
Old Aug 19, 2007 | 12:17 PM
cincyTT's Avatar
I'm make believe
Not sure how the mkii is hooked up. Might still be the same, just install it before the wastegate and your fine. AW is far on the consirvative side 99% of the time. They rather talk about wheels and bs like that. Its still a ko3 and 20-22psi is still doable.
Old Aug 19, 2007 | 12:46 PM
TTsteve's Avatar
Thats cool, I was thinking it should be fine too but just wanted to make sure. I cant see holding boost a little longer being bad as long as you dont go over the turbos limit. Thanks.
Old Aug 19, 2007 | 01:11 PM
cincyTT's Avatar
I'm make believe
THe only way your going to hurt the turbo is by tightening the wastegate to hold boost. The bc isnt going to holdboost to the point of damage.
vlad98023
Mar 9, 2009 07:31 PM
DJ Headbanger
Sep 28, 2008 08:43 PM
audititty
Aug 27, 2008 09:52 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
Bigrigatoni
Oct 29, 2007 11:46 PM
