Boost Guage question
Anybody have a boost guage hooked up and it didn't work..i don't have a boost machine hooked up yet, just running the guage to a 4 bar fpr with a **** installed...is it supposed to work before you have a boost macine hooked up?
hooked underneath the driver panel...ground to the ground wheel, powered to the 75x bolt...tfitting at the fpr, with the nylon hose running from the single t part sticking out to the guage...that's pretty much it
alright i pushed the f(ck out of it into the guage, and it seems to be working somewhat, I think..it only reads up to 15lbs max, but i'm thinking it should be reading more boost than that with all the mods i have on it...apr 91 flash, 3" exhaust, airbox, fmic, etc...and everything's running just like it should, no boost leaks or anything like that
it's an autometer ultralite mechanical...i know it's hooked up right, so maybe it's the guage..i took the hose out of the guage and could hear the pressure coming from the hose at idle...not a whole lot of pressure, kind of faint, but steady...maybe it'll start acting normal like yours did
