Boost leak????
Old Sep 10, 2008 | 09:30 AM
bvgoosedd's Avatar
Red face Boost leak????
How would you know if you have a boost leak or a vac leak?? all i know is i just got my car back i got a forge 004 and i'll been breaking her in so today i finally got on her and at 20psi it starts to stutter. like crazy no cel tho this morning when i got on her. buti keep getting p1136. any ideas
Old Sep 10, 2008 | 10:25 AM
.clipse's Avatar
SoCal Crew Member
pressure test and/or boost gauge.
Old Sep 10, 2008 | 02:35 PM
bvgoosedd's Avatar
i got a boost gauge. what would it say? how do i know. i know i peak at 21psi but it just stutters when i hit that. and i'm between 18 and 20 vac side at ideal but if i'm off the gas in a gear it's closer to 25 on the vac side. also how would i know if my car isn't likeing the forge 004??
Old Sep 10, 2008 | 03:03 PM
.clipse's Avatar
SoCal Crew Member
^ ahh yes... 18-20 hg vac on idle sounds about right... pushing at about ~20 psi... the numbers sound right.
i'm assuming it's a vac. leak if it's the Forge 004. they've been notorious for their valves not staying fully closed at idle~
Old Sep 10, 2008 | 03:57 PM
bvgoosedd's Avatar
yea but i'm have problems when i'm boosting not at idle... so is it the 004?? of a veak???
Old Sep 10, 2008 | 04:05 PM
.clipse's Avatar
SoCal Crew Member
boosting FROM idle, as in studdering when throttling it? or just in idle?
throttling = boost leak.
@ idle = vac. leak.
best way to check is to drop in the DV and see if you're seeing the same problems. if not, then you can single out the 004 as the problem. if you ARE, then you have a leak somewhere~
Old Sep 10, 2008 | 05:09 PM
themysteryman83's Avatar
DV flutter maybe? Are there adjustable springs in the 004 like the others? Maybe you need a stronger spring.
Old Sep 10, 2008 | 06:53 PM
bvgoosedd's Avatar
i've heard of adjusting the 004 but i don't see how. it's a dual piston BOV. any1 know about the forge 004.
Old Sep 10, 2008 | 08:23 PM
.clipse's Avatar
SoCal Crew Member
^ i've ran one, and yes the springs are swappable. Cincy is notorious for using one = probably best bet to ask. try the DV and see if you're seeing the same problems.
Old Sep 11, 2008 | 12:48 PM
bvgoosedd's Avatar
well i was way off. it was the coil packs. lol. i do have a leak somewhere tho. my boy at the shop said it's not a big leak so he'll try to find it sat or sun. i'm using gti coils till my new ones come in. he said it's best to order all of them cus they usally all go bad. i hope that is why i was geting a p1136 but for some reason i bet that is another issue.
