boost leak ? possibly, need help
So i have installed my Boost factory SMIC. Ever since then my car feels like there is less boost. The intake temp is down and the car feels to pull nicer through the entire RPM range. But it doesnt have the same kick it had before with just the Stock mount and my APR 94+ what can i change to fix my problem? i recently bought NgK iradium spark plugs and i change the oil regularly. I also bought a new maf last year. i have vag-ed the car and i found no new codes. Just the regular listed below.\
VAG-COM Version: Release 704.1
Data version: 20070422
Saturday,30,June,2007,20:19:10:60502
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Mileage: 99220km/61652miles
Address 03: ABS Brakes Labels: 8N0-907-379.LBL
Part No: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
1 Fault Found:
01279 - Longitudinal Acceleration Sensor (G251)
57-00 - Electric Circuit Failure
Address 08: Auto HVAC Labels: None
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D02
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
I wish my EFU would work so i can see the boost. Thanks for any suggestions
Coding: 13504
Shop #: WSC 01236
1 Fault Found:
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
well do you have the esp light on? i use to have that one code
1 Fault Found:
its a 105 dollar part from world impex.com behind the glovebox
as far as the boost....did you unhook your map sensor?
1 Fault Found:
I did unplug my map sensor. I bought the EFU unit that has a boost guage but it doesnt seem to work at the moment. Do i need to calibrate the Map sensor. It seemed that there was less airflow over the map sensor inside the new smic because of the flange. Is the a bigger map sensor i can use so more air can pass over the sensor ?
there is nothing to recalibrate. you can make a boost leak tester for cheap and test the system yourself if you have an air compressor.
from boost factory from here
"Another side note is the 4+ psi pressure drop of the stock cooler and the unmeasureable drop of the BFSM.
Another interesting link is the APR site that has enough info for you to draw some interesting conclusions.I do notice they dont mention the ambient temp or the intercooler efficiency.My conclusion from this is that it would take all the same info they provide+ some damm hot ambient temps to equal the BFSM
We tested this BFSM and found it to flow 491cfm@1psi pressure drop "
I built a modshack inspired pressure tester for less than $25. PVC came from Lowes, air fitting from NAPA, integrated pressure gauge from the local welding store. Just get one that reads at least to whatever pressure you expect to boost to. Mine actually reads to 60, not that I'll ever see that, but I like to have my bases covered. ; )
Heres the modshack one http://www.modshack.info/Pressure.htm
