Boostmachine in
:Dlove it. no more crazy boost spikes, hits 20psi in 3rd settles and holds 18psi until 5400-5600 rpms then slowly settles down. the boost onset control is nice too, the boost lost between shifts is gone.
RE: Boostmachine in
word... im getting one soon, i just need to get a boost gauge, which happens to be more expensive then i please
RE: Boostmachine in
what gauge are you getting? Knowing your taste, im guessing awe vent gauge. VDO or Autometer w/ vent ring is under $100
RE: Boostmachine in
haha well i was thinkin the awe gauge... you have a link for that other one?
RE: Boostmachine in
RE: Boostmachine in
ORIGINAL: cincyTT Knowing your taste, im guessing awe vent gauge. Nvm... anyhow, Can the boost machine be installed without the MOFO? I only ask because I'd like to go full up stage 3 modshack... but I wonder whether I need to do them in order. I have the VTDA installed already. |
RE: Boostmachine in
no, he just has ataste for overpriced things, so it was a given.
You can install any of his parts in any order, just aslong as you get the supporting mods (mofo and 4bar). |
RE: Boostmachine in
You can get the AWE gauge @ a bargain ($80 less) if you order the kit for the A3 instead of the TT. Same gauge, comes with trim ring and install kit. Thats what I did, requires a little modification like the Modshack install, if you are interested I can give you pics/info.
RE: Boostmachine in
Need the 4bar for the MOFO... but not for the boost machine, correct? Then I can order the Bosche 4bar and MOFO in a few weeks. Is this also correct?
RE: Boostmachine in
correct,boostmachine, then go ahead and get the 4bar and mofo later.
