Boostmachine in
Old Apr 29, 2007 | 10:08 PM
liTTo's Avatar
Default Boostmachine in
love it. no more crazy boost spikes, hits 20psi in 3rd settles and holds 18psi until 5400-5600 rpms then slowly settles down. the boost onset control is nice too, the boost lost between shifts is gone.
Old Apr 30, 2007 | 01:40 AM
theTTkid's Avatar
Default RE: Boostmachine in
word... im getting one soon, i just need to get a boost gauge, which happens to be more expensive then i please
Old Apr 30, 2007 | 02:54 AM
cincyTT's Avatar
I'm make believe
what gauge are you getting? Knowing your taste, im guessing awe vent gauge. VDO or Autometer w/ vent ring is under $100
Old Apr 30, 2007 | 03:01 AM
theTTkid's Avatar
haha well i was thinkin the awe gauge... you have a link for that other one?
Old Apr 30, 2007 | 03:17 AM
cincyTT's Avatar
I'm make believe
vdo
make sure you buy everything. ecstuning also sells them.
Old Apr 30, 2007 | 10:32 PM
neur0tic's Avatar
ORIGINAL: cincyTT
You know each other?
Nvm... anyhow, Can the boost machine be installed without the ****? I only ask because I'd like to go full up stage 3 modshack... but I wonder whether I need to do them in order. I have the VTDA installed already.
Old Apr 30, 2007 | 10:40 PM
cincyTT's Avatar
I'm make believe
no, he just has ataste for overpriced things, so it was a given.
You can install any of his parts in any order, just aslong as you get the supporting mods (**** and 4bar).
Old Apr 30, 2007 | 11:27 PM
cmh's Avatar
cmh
You can get the AWE gauge @ a bargain ($80 less) if you order the kit for the A3 instead of the TT. Same gauge, comes with trim ring and install kit. Thats what I did, requires a little modification like the Modshack install, if you are interested I can give you pics/info.
Old May 1, 2007 | 12:20 AM
neur0tic's Avatar
Need the 4bar for the ****... but not for the boost machine, correct? Then I can order the Bosche 4bar and **** in a few weeks. Is this also correct?
Old May 1, 2007 | 12:23 AM
cincyTT's Avatar
I'm make believe
correct,boostmachine, then go ahead and get the 4bar and **** later.
